Title | Size | Downloads |
01 Fundamentals Command Reference-book.pdf | 1.06 MB |
Preface
The H3C S5800&S5820X documentation set includes 12 command references, which describe the commands and command syntax options for the S5800&S5820X Release1211.
The Fundamentals Command Reference describes commands for configuring command line interface (CLI), logging in to your switch, configuring FTP and TFTP, file system management, configuration file management, device management, software upgrade and ISSU.
This preface includes:
· Audience
· About the H3C S5800&S5820X documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5800 and S5820X series
Added and modified commands
Compared to Release1110, Release1211 adds and modifies the following commands:
Command reference |
Added and modified commands |
CLI |
Modified commands: Added regular-expression related parameters to all display commands |
Logging in to the switch |
Added commands: · display telnet client configuration · telnet client source · Modified commands: telnet ipv6—Added support for the vpn-instance keyword |
FTP |
Added commands: · display ftp client configuration · ftp client source Modified commands: ftp ipv6—Added support for the vpn-instance keyword |
TFTP |
Added commands: · display tftp client configuration · tftp client source Modified commands: tftp ipv6—Added support for the vpn-instance keyword |
File management |
Configuration file management |
Modified commands: · display current-configuration—Added support for the exclude keyword · save—Added support for the force keyword |
Software upgrade |
Added commands: boot-loader update file |
ISSU |
ISSU related commands are newly added to this release |
Device management |
Added commands: fan prefer-direction Modified commands: display device manuinfo—Added support for the fan and power keywords |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
The H3C S5800&S5820X documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Pluggable module description |
PSR150-A [ PSR150-D ] Power Modules User Manual |
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products. |
PSR300-12A [ PSR300-12D1 ] Power Modules User Manual |
Describes the appearances, features, specifications, installation, and removal of the pluggable 300W power modules available for the products. |
PSR750-A [ PSR750-D ] Power Modules User Manual |
Describes the appearances, features, specifications, installation, and removal of the pluggable 750W power modules available for the products. |
RPS User Manual |
Describes the appearances, features, and specifications of the RPS units available for the products. |
LSW1FAN and LSW1BFAN Installation Manual |
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products. |
LSW148POEM Module User Manual |
Describes the appearance, features, installation, and removal of the pluggable PoE module available for the products. |
S5820X [ S5800 ] Series Ethernet Switches Interface Cards User Manual |
Describes the models, hardware specifications, installation, and removal of the interface cards available for the products. |
H3C OAP Cards User Manual |
Describes the benefits, features, hardware specifications, installation, and removal of the OAP cards available for the products. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the models, appearances, and specifications of the pluggable modules available for the products. |
Power configuration |
S5800-60C-PWR Ethernet Switch Hot Swappable Power Module Ordering Guide |
Guides you through ordering the hot-swappable power modules available for the S5800-60C-PWR switches in different cases. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Provides the RPS and switch compatibility matrix and RPS cable specifications. |
Hardware installation |
· S5800 Series Ethernet Switches Quick Start · S5820X Series Ethernet Switches Quick Start · S5800 Series Ethernet Switches CE DOC · S5820X Series Ethernet Switches CE DOC |
Provides regulatory information and the safety instructions that must be followed during installation. |
· S5800 Series Ethernet Switches Quick Start · S5820X Series Ethernet Switches Quick Start |
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
· S5800 Series Ethernet Switches Installation Manual · S5820X Series Ethernet Switches Installation Manual |
Provides a complete guide to hardware installation and hardware specifications. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
· S5800-60C-PWR Switch Video Installation Guide · S5820X-28C Switch Video Installation Guide |
Shows how to install the H3C S5800-60C-PWR and H3C S5820X-28C Ethernet switches. |
Software configuration |
Configuration guide |
Describe software features and configuration procedures. |
Command reference |
Provide a quick reference to all available commands. |
Operations and maintenance |
H3C Series Ethernet Switches Login Password Recovery Manual |
Tells how to find the lost password or recover the password when the login password is lost. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
